6.3. Advisory HFV-3 (CVE-2026-73093)
Integer overflow in FF-A receiver array bounds check can cause an out-of-bounds access |
CVE-2026-73093 |
Reported on 6th July 2026 |
Hafnium v2.15 |
Hafnium configurations that accept FF-A v1.1 or later memory send requests from an untrusted caller |
Denial of service (Hafnium panic) |
Minwoo Ra |
6.3.1. Description
Hafnium validates the receiver array in an FF-A memory transaction descriptor
before accessing its entries. The end of the array was calculated from the
receivers_offset, memory_access_desc_size, and receiver_count
fields using 32-bit unsigned arithmetic.
An attacker can supply a large receivers_offset that causes this
calculation to wrap around. The wrapped value can pass the fragment bounds
check, while the original offset is subsequently used to form a pointer
outside the copied memory transaction descriptor. Dereferencing this pointer
can cause an out-of-bounds access and panic Hafnium.
6.3.2. Exploitability Details
The issue affects FF-A v1.1 and later memory send requests, for which the
caller supplies the receiver array offset. The caller must be able to invoke
FFA_MEM_SHARE, FFA_MEM_LEND, or FFA_MEM_DONATE and control the
memory transaction descriptor in its TX buffer.
When Hafnium runs as an SPMC, a compromised Normal World component can submit the malformed descriptor and cause an S-EL2 panic. The resulting availability impact is a denial of service.
6.3.3. Mitigation and Recommendations
The issue is fixed by calculating the end of the receiver array using 64-bit arithmetic and rejecting the descriptor when the result exceeds the initial fragment length. This validation occurs before a receiver pointer is formed.
Users should apply the fix referenced below. There is no known configuration workaround other than preventing untrusted callers from issuing FF-A memory send requests.
