Advisory HFV-3 (CVE-2026-73093) =============================== +----------------+-----------------------------------------------------------------+ | Title | Integer overflow in FF-A receiver array bounds check can cause | | | an out-of-bounds access | +================+=================================================================+ | CVE ID | CVE-2026-73093 | +----------------+-----------------------------------------------------------------+ | Date | Reported on 6th July 2026 | +----------------+-----------------------------------------------------------------+ | Versions | Hafnium v2.15 | | Affected | | +----------------+-----------------------------------------------------------------+ | Configurations | Hafnium configurations that accept FF-A v1.1 or later memory | | Affected | send requests from an untrusted caller | +----------------+-----------------------------------------------------------------+ | Impact | Denial of service (Hafnium panic) | +----------------+-----------------------------------------------------------------+ | Fix Version | `Receiver array bound check`_ | +----------------+-----------------------------------------------------------------+ | Credit | Minwoo Ra | +----------------+-----------------------------------------------------------------+ Description ----------- Hafnium validates the receiver array in an FF-A memory transaction descriptor before accessing its entries. The end of the array was calculated from the ``receivers_offset``, ``memory_access_desc_size``, and ``receiver_count`` fields using 32-bit unsigned arithmetic. An attacker can supply a large ``receivers_offset`` that causes this calculation to wrap around. The wrapped value can pass the fragment bounds check, while the original offset is subsequently used to form a pointer outside the copied memory transaction descriptor. Dereferencing this pointer can cause an out-of-bounds access and panic Hafnium. Exploitability Details ---------------------- The issue affects FF-A v1.1 and later memory send requests, for which the caller supplies the receiver array offset. The caller must be able to invoke ``FFA_MEM_SHARE``, ``FFA_MEM_LEND``, or ``FFA_MEM_DONATE`` and control the memory transaction descriptor in its TX buffer. When Hafnium runs as an SPMC, a compromised Normal World component can submit the malformed descriptor and cause an S-EL2 panic. The resulting availability impact is a denial of service. Mitigation and Recommendations ------------------------------ The issue is fixed by calculating the end of the receiver array using 64-bit arithmetic and rejecting the descriptor when the result exceeds the initial fragment length. This validation occurs before a receiver pointer is formed. Users should apply the fix referenced below. There is no known configuration workaround other than preventing untrusted callers from issuing FF-A memory send requests. .. _Receiver array bound check: https://review.trustedfirmware.org/q/Ic54bbc09f7ff604f93d35e7ab5f3523c4250133a
