2.5. Commits Style
When writing commit messages, please think carefully about the purpose and scope of the change you are making: describe briefly what the change does, and describe in details why it does it. This helps to ensure that changes to the code-base are transparent and approachable to reviewers, and it allows maintainers to keep a more accurate changelog. You may use Markdown in commit messages.
A good commit message provides all the background information needed for reviewers to understand the intent and rationale of the patch. This information is also useful for future reference.
For example:
  • What does the patch do?
  • What motivated it?
  • What impact does it have?
  • How was it tested?
  • Have alternatives been considered? Why did you choose this approach over another one?
  • If it fixes an issue, detail what the issue is and provide any pointers/resources that are found necessary.
Hafnium follows the Conventional Commits specification. All commits to the main repository and its submodules are expected to adhere to these guidelines, so it is strongly recommended that you read at least the quick summary of the specification.
To briefly summarize, commit messages are expected to be of the form:
<type>[scope]: <description>
[optional body]
[optional footer(s)]
Signed-off-by: Contributor <contributor@email.com>
Change-Id: 00000000000000000000000000000000000000000
The maximum character counts per line are:
  • 50 for the commit title.
  • 72 for the commit body.
The following types are permissible and are strictly enforced:
Type
feat
A new feature
fix
A bug fix
build
Changes that affect the build system or external dependencies
ci
Changes to CI configuration files and scripts
docs
Documentation-only changes
perf
A code change that improves performance
refactor
A code change that neither fixes a bug nor adds a feature
revert
Changes that revert a previous change
style
Changes that do not affect the meaning of the code (white-space, formatting, missing semi-colons, etc.)
test
Adding missing tests or correcting existing tests
chore
Any other change
In the Hafnium project, commit scopes are mandatory and are enforced by project tooling. All commits must specify a scope identifying the subsystem or functional area affected by the change.
Example:
feat(mm): improve memory allocation path
fix(hftest): correct test failure on arm64
The scope must be chosen from a predefined list of approved values. Commits without a scope, or with an unapproved scope name, will be rejected by CI static-checks.
If none of the existing scopes are appropriate, the patch author is expected to update the list of approved scopes and use the new scope consistently in the same patch set. The list of approved scopes is maintained in the commit message linting configuration file commitlint config
2.5.1. Mandated Trailers
Commits are expected to be signed off with the Signed-off-by: trailer using your real name and email address. You can do this automatically by committing with Git’s -s flag.
There may be multiple Signed-off-by: lines depending on the history of the patch, but one must be the committer. More details may be found in the Gerrit Signed-off-by Lines guidelines.
Ensure that each commit also has a unique Change-Id: line.
If you have followed optional steps in the prerequisites to install the clone the repository using the “Clone with commit-msg hook” clone method, then this should be done automatically for you.
More details may be found in the Gerrit Change-Ids documentation.
2.5.2. Commit Linting
Commitlint helps enforce the conventional commits specification by providing commit message linting capabilities.
Navigate to the Hafnium root directory. Node Version Manager (nvm) is required to install the Node.js dependency for Commitlint. To install nvm run the following command:
wget -qO- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.1/install.sh | bash
To install Node.js, first reload the shell configuration to ensure that nvm is available.
source ~/.bashrc
Run the following command to install Node.js:
nvm install 20
To test that commit linting is working, navigate to the Hafnium root directory and run the following:
make commitlint
By default this will apply linting to the most recent commit message.
Additionally, you can lint any range of commit messages by setting the COMMITLINT_FROM and COMMITLINT_TO arguments. An example of this is as follows:
make commitlint COMMITLINT_FROM=HEAD~3 COMMITLINT_TO=HEAD
Copyright (c) 2023, Arm Limited and Contributors. All rights reserved.
