Advisory HFV-2 (CVE-2026-73092) =============================== +----------------+-----------------------------------------------------------------+ | Title | FFA_NS_RES_INFO_GET may read beyond fragmented memory-send | | | descriptors | +================+=================================================================+ | CVE ID | CVE-2026-73092 | +----------------+-----------------------------------------------------------------+ | Date | Reported on July 8th 2026 | +----------------+-----------------------------------------------------------------+ | Versions | Hafnium v2.14 through v2.15 | | Affected | | +----------------+-----------------------------------------------------------------+ | Configurations | Hafnium running as the S-EL2 SPMC with FF-A v1.3 | | Affected | FFA_NS_RES_INFO_GET enabled. | +----------------+-----------------------------------------------------------------+ | Impact | Disclosure of S-EL2 secure-pool contents to the Normal World | | | and denial of service to the Secure World | +----------------+-----------------------------------------------------------------+ | Severity | CVSS v3.1 7.9 (High) | | | CVSS:3.1/AV:L/AC:L/PR:H/UI:N/S:C/C:H/I:N/A:H | +----------------+-----------------------------------------------------------------+ | Fix Version | `Skip incomplete memory-send transactions`_ and | | | `traverse constituents across all fragments`_ | +----------------+-----------------------------------------------------------------+ | Credit | Minwoo Ra | +----------------+-----------------------------------------------------------------+ Description ----------- Hafnium retains an FF-A memory-send transaction in a share-state entry while its fragments are being received. The composite memory-region header in the initial fragment declares the total number of constituents in the transaction, whereas the share state records the constituents actually received in each fragment. FFA_NS_RES_INFO_GET enumerated allocated Normal World share states without first requiring the memory-send transaction to be complete. It then used the declared total constituent count as the bound for indexing the constituent array following the composite header in the initial fragment. A malicious Normal World endpoint could submit an initial FFA_MEM_SHARE fragment containing fewer constituents than declared and leave the transaction incomplete. A subsequent FFA_NS_RES_INFO_GET call would read beyond the received constituents and interpret adjacent S-EL2 secure-pool memory as constituent records. Completed fragmented transactions also retain continuation fragments in separate allocations. Although completion verifies that the declared count matches the total received across all fragments, it does not make those allocations contiguous with the constituent array in the initial descriptor. FFA_NS_RES_INFO_GET therefore must resolve each constituent through the share state's fragment array rather than index every constituent from the initial fragment. Exploitability Details ---------------------- Exploitation requires control of privileged Normal World software, such as an NS-EL1 operating system or NS-EL2 hypervisor, that can issue crafted FF-A calls. Hafnium must be operating as the S-EL2 SPMC, FFA_NS_RES_INFO_GET must be enabled, and the caller must be able to initiate fragmented memory-send transactions. When the receiver endpoint can be resolved, out-of-bounds values may be interpreted as memory constituents and returned to the Normal World as FF-A address-map descriptors. This can disclose values derived from adjacent S-EL2 secure-pool objects, including address-like values, endpoint metadata, permissions, and in-flight descriptor contents. When the receiver endpoint cannot be resolved, no address-map descriptor is emitted and the response-page budget does not terminate constituent traversal. An incomplete transaction with a large attacker-controlled constituent count can consequently cause a long-running loop in S-EL2, preventing the FF-A call from returning and starving Secure World execution. No out-of-bounds write, control-flow corruption, or integrity impact has been identified. Mitigation and Recommendations ------------------------------ The fixes prevent FFA_NS_RES_INFO_GET from traversing incomplete memory-send transactions and resolve constituent indices through the allocations recorded in the share state's fragment array. Together, these changes ensure that only fully received transactions are reported and that every constituent is read from the fragment that stores it. Users of affected configurations should apply both fixes. If the fixes cannot be applied immediately, integrators should prevent untrusted Normal World software from invoking FFA_NS_RES_INFO_GET or initiating fragmented memory-send transactions. .. _Skip incomplete memory-send transactions: https://review.trustedfirmware.org/q/I4daf28e0a47d32f1176caa5228038e961176b967 .. _traverse constituents across all fragments: https://review.trustedfirmware.org/q/I9dbb5df7f0cfbd0540df1886353ac038f44ecd1c
